PTV Clearance Question
I am getting ready to put a 235/239 comp cam in my 2006 LS2, I wasn't planning on taking the heads off and wondered if there was a way to check my PTV with my heads on?
Yes, you will need checker springs, adjustable push rod, dial indicator and a degree wheel. I would compress the lifter and let it bleed for a good ten minutes. Then with zero lash measure accurately with the degree wheel.
Ok, last question.
Is there software or something I can plug my cam numbers into to see if I need to go to these lengths to check the PTV clearance?
I have an LS2 with stock block/heads but want to put in my 235/239 .620/.621 lift 112 + 4 cam.
LS1TECH & Trucks Sponsor
it is always recommended to measure your piston to valve clearance, especially when installing a large camshaft. That being said, we have fit larger camshafts on stock block/stock head LS2s. That cam is somewhat similar to our Tsunami camshaft which will fit in a stock motor as long as its installed correctly.
Just to put my 2 cents worth for future reference...
Stock LS1 block, stock 243 heads, stock LS1 compressed head gasket, 54-456-11 comp cam (219/227 @.050, .607/.614, 112 + 5...installed at 106.5). Exhaust PTV is fine. Intake isn't even in the ballpark. About .035. It really makes me wonder where some of these specs and clearances are coming from and why the huge differences we see from engine to engine, cam to cam.
That is not good enough. I did that and found 3/8" clearance before the valve bottomed out inside the relief.
Then I verified with clay and found out the intake valve was barely missing the edge of the relief ~.07".
Use clay.
Use clay.
