manual transmission fluid..help
trying to see if i use straight atf fluid(mobil 1 synthectic) or add a quart of gear oil...did a lot of searching but no luck.................
ATF only, definitely do not put gear oil in it
I just changed mine today with plain old $2.50 a quart cheapo ATF which is what most builders recommend, replacing the synchromesh I've been running to see what happens
Im using mobil 1 ATF, work better then regular dex 3 for sure, I try adven auto part dex, drain it after a week, try valvoline dex, drain it after 2 week, then put in mobil1 and it stay their for ever lol.
Use non-synthetic ATF. The earlier year T56 from '98-'00 have paper blocker rings and synthetics will damage them. '01+ switched to carbon, and the damage is not an issue however I've heard of grinding issues due to the different friction properties of the synthetic.
Like I said, I'd stick with conventional ATF. Synthetic really doesn't buy you much in a manual trans as it isn't subject to the heat and abuse of engine oil, so the fluid lubricating properties don't break down.
some builders down in Australia recommend to use Castrol Tranzmax Z and seen few people use it down here for Manual transmission. I always thought it was supposed to be for Auto trans!
