lt1 parts bolt on to 350 long block?
Old 02-21-2011, 08:49 PM
lotsaboost's Avatar
Default lt1 parts bolt on to 350 long block?
will my lt1 parts like intake and other things like my ecu be compatible with this engine? http://www.blueprintengines.com/inde...355-bp35512ct1
Old 02-21-2011, 09:04 PM
93M6Formula's Avatar
The LT1 block is very similar to a Gen 1 SBC but has many unique differences that won't allow you to use LT1 parts on that motor.
What are your plans? we need a lot more info on what you want to accomplish.
Old 02-21-2011, 09:06 PM
stryker1320's Avatar
Compatible without modification ... no. Can it be made to work tho....yes. Good luck with the opti tho. That is a Gen 1 small block, not an LT1.
Old 02-22-2011, 02:42 AM
Sublime Dak's Avatar
Pretty much only the valve covers, engine internals, and intake with modification will work. The heads will not work, neither will the timing set, timing cover, water pump, oil pan, opti etc etc.
Quick Reply: lt1 parts bolt on to 350 long block?
