Help!
Old Feb 20, 2011 | 12:02 PM
95BlkBird's Avatar
Default Help!
Heads are back on and headers are on. Problem is I can't get to 3 plugs to tighten them. Pacesetters midtubes are the headers. Any suggestions?
Old Feb 20, 2011 | 12:16 PM
jaycenk's Avatar
Pull the headers back and in the future use a shorter plug socket with 6 point hex on the end. Makes it a breeze.
Old Feb 20, 2011 | 12:20 PM
LSWHO's Avatar
If you have a socket that goes on and has a fitting for a regular wrench on it usually that allows for enough clearance for the plugs with headers on.
Old Feb 20, 2011 | 04:19 PM
defaultexistence's Avatar
Hey! i got it! use a socket with a hex end for a wrench!?
Old Feb 20, 2011 | 05:07 PM
jaycenk's Avatar
LOL No use hex ended socket with a wrench
Old Feb 20, 2011 | 05:23 PM
95BlkBird's Avatar
I bought some offset ratcheting wrenches that i think will work. I got an offset normal wrench in there but its a pain to tighten but it was possible. Not sure but ratcheting wrenches might be too fat to fit in there. We shall see tomorrow. Thanks guys
Old Feb 21, 2011 | 06:05 PM
LOL No use hex ended socket AND "loosen then tighten" with a wrench!
Dont forget your AntiSneeze, and gap them ***** properly
Old Feb 21, 2011 | 06:38 PM
AChotrod's Avatar
I ground down a spark plug socket that has the hex end so you can turn it with a wrench. Works pimp!
Old Feb 21, 2011 | 06:57 PM
camar0corey's Avatar
Well that is probably cheaper than buying the SLP socket like I did years ago. I love that SLP socket though, plugs are in and out in no time.
Old Feb 21, 2011 | 10:14 PM
jaycenk's Avatar
WoW amazing look at all the Florida Boyz in the house !!! lol
Old Feb 21, 2011 | 10:21 PM
Lawhead's Avatar
I seen a set of them pacesetter mids and thought this same exact thing HOW IN THE HELL COULD YOU GET TO THEM PLUGS!?!!
Old Feb 21, 2011 | 10:45 PM
BigD383lt1's Avatar
I ground down a spark plug socket as well... To me this is as important as your lug lock key I will never do it again with out it. Just buy a cheap one at the parts store and grind it front and back and remove the rubber boot so it swings around better. Oh and I had to drill out the center because the spark plug was bigger around then the opening further in.
Old Feb 22, 2011 | 07:09 AM
Mids suck!,Shorties Suck! might as well be Stockers!
