lt1 parts bolt on to 350 long block?
will my lt1 parts like intake and other things like my ecu be compatible with this engine? http://www.blueprintengines.com/inde...355-bp35512ct1
The LT1 block is very similar to a Gen 1 SBC but has many unique differences that won't allow you to use LT1 parts on that motor.
What are your plans? we need a lot more info on what you want to accomplish.
Pretty much only the valve covers, engine internals, and intake with modification will work. The heads will not work, neither will the timing set, timing cover, water pump, oil pan, opti etc etc.
