370ci Rearmount turbo 76mm ball bearing
Old 02-22-2011, 09:55 AM
SSFAST's Avatar
Default 370ci Rearmount turbo 76mm ball bearing
This is a 2002 SS Camaro
Here are the results of my turbo build: 808rwhp, 880 tq on a mustang Dyno
My build:
370cu iron block
diamond pistons
stock crank
ARP everything
turbo cam spec by Tony Mamo
AFR 225 heads 73cc
Comp star rods
80lb injectors
76mm precision turbo with 1.32 twin screw housing
12 bolt rear
M6 with Mcleod twin disk clutch
18.9 lbs of boost
meth kit w/ twin nozzle
Bump for the rearmount turbo guys
Old 02-22-2011, 10:31 AM
WSsick's Avatar
Stout numbers for a MD. You need to get some videos of this tire fryer!
Old 02-22-2011, 11:07 AM
SSFAST's Avatar
I know, it was practically spinning on the Dyno
Old 02-22-2011, 01:22 PM
RJB01camaross's Avatar
Great setup!!! I look forward to a video in the future!
Old 02-22-2011, 01:36 PM
N2OBaby's Avatar
Thumbs up
Great numbers.
Would love to see what that beast would do in the 1320.
Old 02-22-2011, 07:32 PM
navyblueSS's Avatar
Nice numbers!
Old 02-22-2011, 08:50 PM
Blownz28man's Avatar
Not bad! Nice numbers! Self built kit or STS? Pipe size?
Old 02-22-2011, 09:50 PM
180ls1's Avatar
Pumpgas? that is some stout numbers there.
Old 02-22-2011, 09:55 PM
bayer-z28's Avatar
Nice! What are you running for an exhaust? Manifolds? Wrapped LT's and Y? Any non-meth numbers? Figure 770?
Quick Reply: 370ci Rearmount turbo 76mm ball bearing
