No lock up in OD
No lock up in OD
I just had a performance rebuild done on my transmission and my stall convertor rebuilt as well. The car drives and shifts perfect until I get on the highway the my problem is that at cruising speeds OD never locks up. The new transmission and stall only have about 50 miles on them since rebuild. I messed with the shifter on the highway and it is shifting into OD but the RPM's are much higher than they should be .... My car has 2.73 gears and at 2,000 RPM's in OD it used to be driving at 80 now at 2,000 RPM's the car is only doing 60 and feels as if it isn't locked
What could be my problem here ?
Open to suggestions .... Thanks
I forgot to mention there is no check engine light and I checked for codes anyways and there are none which relate to the transmission .... I also thought my tune may have been lost but it is still in there .
PCM programming is the same I already checked that because I own HPTuners and my tune is still programmed to the PCM as it was before. There is no check engine light on and there were no trouble codes popping up on HPTuners which relate to the transmission .... The converter was a lock up model but I had to have it rebuilt because of metal getting in there and damaging it and it was supposed to be built to the same specs as when I first bought it ....
What engine DTC's can prevent the TCC to lock up Jake ?
Jake I have the same DTC's as before the transmission was taken out ....
1 that pops up occasionally because of no rear o2's and a few because of restraints which should have nothing to do with it and never caused problems before ....
slow67 How do you command lock up I have never done that ? I have HPTuners and know it can be done just I am unaware of how to command it ?
Oh ok I believe I may have tried that the other night. What do I click in that tab to lock it up though ? TCC Solenoid ? There's a few different options in that tab .... Thanks
I tried that and still no lock up .... I am starting to think the problem isn't vcm related . The only codes I have remaining are restraint and brake pedal codes I'd have to scan again to see which exact ones, but I could not figure out where to disable them anyways ....
