What size amp can i use? detailed info inside
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
Powerbass B-series 12" subwoofer, 250W (rms), Dual 4 Ohm VC
Basic Features
# Backplate: Bumped and Dip Cut Back Plate
# 12 inch woofer with black cosmetics
# 50 oz magnet
# Advanced Polyproplene Cone
# Black Top and Back Plate
# Customized Rubber Boot
# Oversized Control Surround Design (CSD)
# Rigid Black Frames
# Pole piece: Vented Pole Pieces
# Spectrum Analyzer: Progressive Flat Spiders
# Voice Coil: Dual 4ohm VC
# Voice Coil: Multi-Layered Voice Coils
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
# Frequency Response: 30 Hz - 1 KHz
# Peak Power (Maximum): 350 Watts Peak
# RMS (Continuous) Power: 250 Watts
# Sensitivity: 87dB @ 1W/1M
I have 2 subs and now need a amp to power them.
I do NOT know how to calculate the rms and peak to get the answer i need.
All i know is the guy i got these from said he used a 1000 watt 2ch amp and
since he didnt know what was the info the subs i did some research and found
the above info so i just want to make sure i dont under/over power them
What size amp is recommended to push these?
thanks
Basic Features
# 50 oz magnet
Specifications
# FS= 29.8HZ
# QTS=0.78
# VAS=118.9Hz
thanks
With 2ea., Dual 4ohm VC you can wire them for either 1ohm load, or 4ohm load on the Amplifier.
Find a Mono Amplifier that can put out 500-700 rms watts at either 1ohm or 4ohm load, depending on how you want to wire them to the Amplifier. If you want the lowest possible cost then look for a Amp that puts out 500-700 rms watt with a 1 ohm load.
to be honest im searching craigslist for used amps 2 ch and mono under $150 but if bought new i guess $200-$300. i found a kenwood kac-9103d for $80 idk if its too much power tho info below
mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
1-ohm stable (no power ratings available)
CEA-2006 compliant
variable low-pass filter (50-200 Hz at 24 dB per octave)
bass boost (0-18 dB at 40 Hz )
subsonic filter (15/25 Hz, 18 dB/octave )
top-mounted controls
Class D design
speaker- and preamp-level inputs
preamp outputs
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
14-7/8"W x 2-9/16"H x 11-1/2"D
warranty: 1 year
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
ok found some more amps according to the specs of the subs im using which amp below is best for it the SONY, KENWOOD, KICKER OR LANZAR? mono or 2 channel whats better?
SEE SPECS BELOW
SONY XPLOD
1600W max power
500W x 1 into 4 ohm, 20Hz - 300Hz, @ 0.2% THD
900W x 1 into 2 ohm, 20Hz - 300Hz, @ 0.6 THD
Class D
Variable 50 - 300Hz 12dB/oct Low Pass Filter
40Hz EQ Boost
RCA and Speaker Level Inputs
Kenwood mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
CEA-2006 compliant
Class D design
preamp outputs
fuse rating: 40A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
12-7/16"W x 2-1/2"H x 11-11/16"D
warranty: 1 year
Kicker KX600.1
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 300 watts x 1 channel
RMS Power @ 2 ohms 600 watts x 1 channel
RMS Power @ 1 ohm Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Amplifier Specifications
Number of Channels 1 - Mono
Total RMS Power Output 600 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.5%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover N/A
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB (40 Hz)
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 30A x 2
Lanzar VCT2110
Number Of Channels: 2
Maximum Power: 1000 Watts
Low Frequency response: 15 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
500W x 2 Output @ 2 Ohms
1000W x 1 Bridged Output @ 4 Ohms
General Features
2 Ohm Stable
MOSFET Power Supply
Variable Hi-Pass :40 Hz-250 Hz
Variable Low-Pass : 40 Hz-250 Hz
Variable Input Level (Gain) Control : 6V-200mV
Bass Boost Selector : 0/+18dB
Thermal / Overload / Short Circuit Protection
Soft Turn On/Off
Power & Protection LED Indicator
Low Level RCA Input: 10K Ohms
Line Level RCA Output
Frequency Response : 15 Hz-30K Hz
Signal to Noise Ratio: >95dB
THD:0.1 %
2x30 Amp Maxi Type Fuse
Slim Size Amplifier Design For Easy Installation
Dimensions: 10.63''W x1.75''H x 9
SEE SPECS BELOW
SONY XPLOD
1600W max power
Class D
40Hz EQ Boost
CEA-2006 compliant
Class D design
preamp outputs
warranty: 1 year
Kicker KX600.1
Subsonic Filter N/A
Fan Cooled Yes
Fuse Rating 30A x 2
Lanzar VCT2110
General Features
2 Ohm Stable
MOSFET Power Supply
Soft Turn On/Off
THD:0.1 %
