TT2 Centercap removal problems
Old 02-26-2011, 12:34 PM
Stang-Slayer's Avatar
Default TT2 Centercap removal problems
I am having a major pain in the dick removing the center caps. I used a 2.5mm and was able to remove all the bolts off of two wheels (minus the 2 I stripped) and then went to the front wheels and its just a slight **** hair too big to even fit in them. Any ideas? I tried different wrenches but nothing comes close
thanks for the help!
Old 02-26-2011, 07:51 PM
wysemunky's Avatar
maybe take a hammer and tap it in there and after you get them out get some new bolts, they are cheap and include a new allen wrench to fit.
Old 02-26-2011, 08:44 PM
59 camaro's Avatar
i had the same problem on mine, i drilled the screw out with a very tiny drill bit and did it very carfully. after that i was done with the bull **** allen wrench screws, went to a hardware store and bought all new stainless steel phillips screws for my caps
Old 02-26-2011, 09:59 PM
Well I got em out, its weird, for my 315 wide wheels they were metric, for my 275 wide's they were standard, makes no sense.
Either way had to drill out two heads of the screws to get em off.
Any idea how to get the threaded part out without messing up the threads of the wheel?
Old 02-26-2011, 11:49 PM
99'CajunFirehawk157's Avatar
FWIW, use some never seize...
Old 02-27-2011, 05:12 AM
Undertow74's Avatar
yea that seems to be a normal thing, happend to mine when they were brand new trying to put the caps on. Like said above, i went to the hardware store and got some stainless phillips screws to put on there
Old 02-27-2011, 09:55 PM
59 camaro's Avatar
mine came off when i drilled them out, it just seemed to come off with very lil effort
Old 02-28-2011, 07:36 AM
Can u go to any random hardware store and find em?
did u drill all the way through? Did it mess up the threading on the wheels?
Old 02-28-2011, 05:31 PM
59 camaro's Avatar
i drilled all the way in. nothing got stripped. make sure u drill right in the center
Old 03-15-2011, 08:31 PM
Wing Zer0's Avatar
Alright guys any advice on what to do if I bought. Some replacement Phillip head screws and those just slide right in.lol When I bought my tt2 2nd hand. I didn't realize that the screws for the centercaps were all stripped. And the ones that were missing, seems like the original owner probably already tried to drill the screw out and stripped the hole. Which is what i'm guessing. Any help as to what would be the next step? Would be appreciated thanks.
Old 03-18-2011, 06:04 PM
moneypit00's Avatar
hope you have tap and die skills. If not I'd get some help fron a friend. You need to select a new machine screw size that's slightly larger. Drill all holes with the appropriate bit and tap the holes. Might as well do them all so all screws match. Buy stainless phillips machine scews the a conical seat. Antisieze when your done.
Old 03-19-2011, 09:10 AM
nwalton29's Avatar
Next time it happens, use a reverse drill bit. Works like a charm.
Old 03-21-2011, 08:46 PM
Wing Zer0's Avatar
Dam!! That reallly sucks. By chance would this task be something along the lines of what a welder might take on? Because, yes I don't have skills, or the tools for that matter.lol
