Assembling your own motor.
Old 03-06-2011, 08:35 PM
94NDTA's Avatar
Default Assembling your own motor.
With limited automotive knowledge...Anyone ever do it? I am not a mechanic, but have worked on a number of cars, pulled motors/trannies/etc, but have never put a motor together. Good project, or poor idea.
Old 03-06-2011, 08:38 PM
wrd1972's Avatar
Skilled folks with the right tools do it routinely. I generous amount of useful knowledge can be found on the boards.
Old 03-06-2011, 08:42 PM
05HD's Avatar
I suppose that depends on the outcome.
The first engine I built myself burned some oil because I didn't gap the rings right. The first engine a friend of mine built kicked a rod thru the side of the block half way down the street on its maiden voyage. Mine was a good learning experience, my friends was an epic failboat.
Old 03-06-2011, 08:43 PM
the_merv's Avatar
Not hard to do..just assemble to the specs.
Old 03-06-2011, 08:53 PM
tricked94camaro's Avatar
love your monte project merv!
Old 03-06-2011, 09:01 PM
merim123's Avatar
if you do it right, you'll realize how much time it takes and writing stuff down, test fitting, etc...
When I did my valve springs, I checked the installed height on every spring and then wrote all that down, went to buy the shims, etc... It's not hard, time consuming and you need to be meticulous so that you don't throw a rod on a maiden voyage.
If you have to clearance the block for a stroker, that ups the game a little too.
Old 03-06-2011, 09:02 PM
LigHtEmUp01's Avatar
as long as u keep a clean work place and at leat talk to an engine builder when u have a question and follow the torque specs u should be alright
Old 03-06-2011, 09:04 PM
the_merv's Avatar
Thanks man..alot of work went into it..
Old 03-06-2011, 09:09 PM
prolly should have commented the build thread lol but oh well. i fkin love 80's g-bodies!
Old 03-06-2011, 09:21 PM
quik95lt1's Avatar
ive done quite a few of them..........heres the build thread on mine........gonna update it tomorrow with all the new assembely pics of the motor........
it may have some useful info for you
https://ls1tech.com/forums/lt1-lt4-m...ld-thread.html
Old 03-06-2011, 09:51 PM
94NDTA's Avatar
How much do you save doing it yourself vs buying a short block or having a shop do it?
Old 03-06-2011, 09:55 PM
gregrob's Avatar
Buy a book (assembling chevy 350 engines), check out Karl ellweins site for tips, take your time, ask questions, don't make ANY ASSUMPTIONS.
Old 03-06-2011, 09:56 PM
gregrob's Avatar
Not much if it blows up... Call Clayton Racing and see if you have the budget for them to do it. They do extremely quality work.
Old 03-07-2011, 09:15 AM
James Montigny's Avatar
A stock rebuild is a great way to learn how it all goes together.
There are many, many books on the subject and no shortage of expertise around for questions.
At the very worst, if something goes wrong, it's not like there aren't a sea of rebuildable
Lt1 shortblocks available on the used parts market.
A heavier (and more expensive) build is probably best left to someone with a few more notches on his belt
if only to avoid the devastating blow of destroying a motor you put a lot of money into.
Pay close attention to where each part goes and how much torque is required.
Some parts fit backwards or in the wrong location and seem fine ... until the motor vibrates itself to bits.
Old 03-07-2011, 09:33 AM
01ssreda4's Avatar
I say let a machine shop do the short-block, you do everything else.
Quick Reply: Assembling your own motor.
