What is this fitting?
This came on the pump in my Spectra EFI tank.
And this adapter came in the box:
Is it SAE 45 degree? I thought those were only for low pressure applications. I don't want to use the barbed fitting either. Is there an adapter that will get me from the flare on the line to a -6 fitting?
Thanks,
Colin
Thanks,
Colin
I've since figured it out. The flare is a 45 deg SAE.
I used Aeoroquip fitting # FCM-1134 to attach directly to the fitting on the pump and threw the brass fitting away. That's a -6 to 45 deg swivel hose end. It's for Aeroquip TFT hose, so you'll at least have to use that type of hose off the tank (which I found easier to work with than standard -6 braided hose anyway).
