what are you 1st gen camaro/firebirds running fo oil pans
Old 03-09-2011, 12:35 PM
s10pro's Avatar
Default what are you 1st gen camaro/firebirds running fo oil pans
running stock style steering not rack
Hummer H3?
modded f-body pan?
any mod the sub frame for stock f-body pan with out cutting pan,or is it the steering that gets in the way, any help would be great. I am open for what ever seeing that i dont have headers orplates and mounts yet, i want a combo that works ,thanks kevin
Old 03-09-2011, 01:39 PM
bmf5150's Avatar
I'm using autokraft pan,street and performance engine plates and I will be using stainless steel works headers,they where made to be used with the s&p plates!
Old 03-09-2011, 01:56 PM
Indyjc's Avatar
Stock oil pan with 2.5 inches cut out. Stock steering, sub frame etc. no problems after 4 yrs. The alt. is close to the frame so I ground a little off the housing it's tight but no rubbing. Good luck.
Old 03-09-2011, 04:04 PM
flyinsquirel's Avatar
Here's what I used, although I hear Edelbrock is no longer making exhaust products. Not sure if they are still making mount plates, but you could make some with the same hole spacing.
https://ls1tech.com/forums/conversio...-body-pan.html
Old 03-09-2011, 05:29 PM
bczee's Avatar
I have one of the RetroLSX pan and made up some Edelbrock copies.. I think the pan will be marketed by Holley from what we have seen here on the forum.
Old 03-10-2011, 08:17 AM
BBC632Camaro's Avatar
Anyone used the GM Performance Muscle Car Pan Kit? I always thought those looked like a good deal.
Old 03-10-2011, 08:40 AM
zenscamaro's Avatar
I'm going to try the camaro oil pan from years 98-2002. Pace has the kit for a good price. Part #pac 8771.
Old 03-10-2011, 02:00 PM
bczee's Avatar
The GM Muscle kit is using the H3 Hummer / LH8 pan. it has good clearance due to the smaller rear sump.. but it does hang down a bit too much for lowered cars..
For the F-Body pan, using Standard adapter plates.. might be a problem with Tie Rod/Cross link hitting the pan. solutin would be to notch the F-body pan.
Quick Reply: what are you 1st gen camaro/firebirds running fo oil pans
