vanishing coolant
Old 03-09-2011, 08:34 PM
93z28ltone's Avatar
Default vanishing coolant
I went out started my car today when I started it I noticed my low coolant light was on so with it running took the cap off the radiator and filled it back it took a 1/2 gug of coolant to do it I have not noticed any leaks I've changed the plugs no coolant on plugs changed the oil this last weekend no milkness in it any other ideas would be helpful
Old 03-09-2011, 09:03 PM
James Montigny's Avatar
Is this the first time you've noticed it low?
And is there coolant in your overflow tank?
Old 03-09-2011, 10:21 PM
rich5368's Avatar
Could be burning it. Sounds like it could be the beginning of head gasket trouble.
Old 03-09-2011, 11:11 PM
shbox's Avatar
Could be a slow leak at a hose, radiator tank, pipe from radiator to coolant reservoir, etc. Sometimes they never reach the ground.
Old 03-09-2011, 11:36 PM
myltwon's Avatar
reservoir can be hard one to spot, also small leak in a hose.
best thing to do is to rent/buy a cooling system pressure tester or atleast get under the car and clean off everything then check again after you've ran it for a bit.
Old 03-09-2011, 11:42 PM
93z28ltone's Avatar
none in the res ether which caused the coolant light and yeah when i bought it top hose clamps were bad and leaking coolant i change the clamps and that fixed that leak and havent noticed any coolant lose until now i check my coolant every week also ive notice under load it starts to get hot and i have a 160 therm in it when i say hot i mean right between a half and 3/4 on the temp gage also my heater hasnt worked since ive owned the car it dont blow hot when its freezing out side but when its warm it works just fine
Old 03-09-2011, 11:44 PM
myltwon's Avatar
heater core could be leaking, check the passanger floor area for wetness
Old 03-09-2011, 11:46 PM
93z28ltone's Avatar
done that and no coolant leak
Old 03-09-2011, 11:56 PM
myltwon's Avatar
alright well next step would be a pressure test, anything else is guessing and feeling for wet spots.
Old 03-10-2011, 12:11 AM
93z28ltone's Avatar
how do you do the pressure check
Old 03-10-2011, 07:04 AM
shbox's Avatar
You rent or buy a pressure tester, pump the system up to operating pressure and look for leaks. This way you can do it safely with the engine cold.
Old 03-10-2011, 07:09 AM
lt170chevelle's Avatar
I had a very similar problem last year and ended up being the begining of a head gasket. Took a while before it got worst.
X2 on the pressure test..rent one from a parts store.
Old 03-10-2011, 10:42 AM
~BuMps AloT~'s Avatar
Do a pressure test
Old 03-10-2011, 10:51 AM
I ran into that a few years back, the stupid cap wasn't holding pressure.
I didn't realize where my coolant was going until we pumped it up to 18psi
Cheap fix; new radiator cap.
Old 03-10-2011, 11:01 AM
idformula's Avatar
I had a similar problem, I used a jug of pre mix over the course of a coupple of months so it was a slow leak, and it turned out being on the pass side of the radiator where it mounts developed a crack. X2 on doing a pressure test.
Old 03-12-2011, 03:46 PM
93z28ltone's Avatar
doing a pressure test today im waiting for the car to cool down so i can do it i noticed alot of coolant around the overflow tank down underneath the battery and around the lid to it ive been putting the coolant in the radiator it self so i am going to check around there to see if theres a leak
Old 03-12-2011, 04:13 PM
Village Troll
SS RRR's Avatar
Check around the seams of the radiator as well.
Old 03-12-2011, 04:45 PM
93z28ltone's Avatar
i check the pressure and the return coolant line to the radiator from the back of the heads was leaking i turned out to be a bad clamp now i checked it agian after that and it holds presure for about 5 mins then starts to go down really slowly were before i did that it was loosing presure fast any other ideas ive checked the radiator and all the hoses
Old 03-12-2011, 04:46 PM
joelster's Avatar
Reach behind each cylinder head and run your fingers along the banjo bolts on the back of each cylinder head. A small leak there would run down the bellhousing and be pretty hard to trace.
Old 03-12-2011, 04:57 PM
Cheap Guy's Avatar
As mentioned above, vanishing coolant was the sign my head gasket was going. It was just small enough that my oil was not milky and it actually took a while for it to overhead. When the head was off, we could see where the gasket failed. The only way I found out (other than it overheating) was a pressure test.
Quick Reply: vanishing coolant
