Pre Lube tool
Pre Lube tool
I was over at a friends shop the other day and came up with a idea for a pre lube tool. He has an old stainless steel water fire extinguisher and I was checking it out. It got me to thinking that I could take the filler off the dip tube, put the proper fittings on the hose, fill it with oil and use it to pre lube my engine. You can charge them with 100psi of air so I will set the regulator on my air compressor and leave it hooked up to power it. I just bought one on e-ghey for $39.99 shipped.
Here is a Link to it:http://cgi.ebay.com/BADGER-Water-Fir...item3365df29ea
Let US know how it works.
thanks,
Jim
thanks,
Jim
I thought about doing the same thing with an old propane cylinder.
What didn't seem promising was how to keep all the oil from running back out of the galleries when I unbolted it from the engine.
In the end I just did what GM says to do when starting their crate motors, pull the plugs and crank it for 30 seconds at a time until I got oil pressure. A lot less messy that way.
I succombed and bought the melling mpl-101 preluber yesterday; showed up today. If only someone had the metric adapter to go on the galley plug
Well, I'll get mine prelubed sometime soon. Looks like a nice little unit; just expensive. However, premature engine failure is more expensive....
