95 z28 turns over wont start!?!
Old 03-10-2011, 11:09 PM
Swoveland's Avatar
Default 95 z28 turns over wont start!?!
I just bought another camaro and it will turn over but wont start
I've already replaced the opti the fuel pump starter and icm coil, i think it might be the computer.... any help is appreciated.
Old 03-11-2011, 08:40 AM
speedZ28's Avatar
Check your injector fuses! I think its a 15 under the hood! Iv hurd of this happening and its dun it to me once or twice!!
Old 03-11-2011, 08:50 AM
Gojira94's Avatar
^^This
Also check your grounds- 1) copper braid from coil stud to frame under ABS pump/modulator assembly, 2) right side block just forward of knock sensor, 3) additional ground on the starter...
Old 03-11-2011, 09:41 AM
djjab57's Avatar
Ive bought a bad ICM before, I would double check that
Old 03-11-2011, 10:58 AM
Swoveland's Avatar
its getting fuel just no spark
Old 03-11-2011, 12:34 PM
speedZ28's Avatar
^^this!!!
Ok your getting fuel! How did u check that!!!
Old 03-11-2011, 02:48 PM
Swoveland's Avatar
i can smell it
Old 03-11-2011, 03:09 PM
LT1559's Avatar
my bet is on the icm...check the pigtail connection just incase there is any kind of buildup or corrosion on it.
Old 03-11-2011, 04:51 PM
BBC79Z's Avatar
Ive had the opti pig tail get a short in it and not start.
Old 03-18-2011, 12:42 PM
LT1559's Avatar
Oh that reminds me, the opti pig tail just randomly popped out on mine and i wasn't able to start it...i guess the tab that held it was broken by the last owner...i payed $50 to get it towed home and 5 minutes after the driver left i looked at the opti and there it was sticking out
Old 06-13-2011, 06:03 PM
edgartorres's Avatar
Default 95 z28 camaro
i just bought a 95 camaro z28 the problem is that it turns on but its rare when it does and when it does i could only use it for like ten mins and then it turns off what can the problem be
Quick Reply: 95 z28 turns over wont start!?!
