mounts- what type?
Old 03-12-2011, 09:16 AM
farmington's Avatar
Default mounts- what type?
Putting headers and ory on my vert and thought it would be a good time to change the engine mounts, trans mount and torque arm mount. What type of material do you recommend and why? Rubber, urethane, prothane, ?
Old 03-12-2011, 10:31 AM
parks450's Avatar
I like polyurethane, because it lasts longer and more resistant to heat and breakdown
Old 03-12-2011, 11:51 AM
sjsingle1's Avatar
i have polys in the engine......but some swear by solids.....so pick your poison
Old 03-12-2011, 11:53 AM
sjsingle1's Avatar
Old 03-12-2011, 02:04 PM
parks450's Avatar
THe way I understand it is solids are good for drag racing and poly is good for a DD, solids you can feel more engine vibration, which I wouldnt like to feel, but thats me
Old 03-12-2011, 05:28 PM
dannyo210's Avatar
Go with polys for the motor mounts, you won't be disappointed. Not sure if changing the stock trans and torque arm mounts are necessary though.
Old 03-13-2011, 01:34 PM
02 Camaro's Avatar
I change all the mounts on my car and went to polyurethane and it worked out perfectly
Old 03-13-2011, 03:53 PM
farmington's Avatar
thanks for the replies. Was leaning towards polyurethane but now that's the way I'm going to go. Going to change them all when I'm doing the headers install
Old 03-14-2011, 12:53 PM
jester1614's Avatar
I am in the process of that as well, did a poly trans and tq arm mount 2 years ago and loved em, doing poly motor mounts while the motor is being built
