95 trans am injectors not pulsing...
Old 03-12-2011, 10:16 AM
LeonbergerG's Avatar
Default 95 trans am injectors not pulsing...
I have tried everything on this car but can't figure out why the injectors wont spray...the fuses are good. Could it be the opti? ? Has fuel pressure 42lbs when primed but will not start.has spark....just no fuel.
Old 03-12-2011, 06:14 PM
jester1614's Avatar
have you checked for signal pulse at the injectors? you would need a "noid light" set to check this.
that is the first thing i would do is check for injector signal
Old 03-12-2011, 08:06 PM
WS Sick's Avatar
Check the wiring to your opti.
Old 03-12-2011, 08:42 PM
WS Sick's Avatar
Forgot to add, the low res from the opti is what tells the PCM where the cam is and it determines what injector to fire and when , no low res pulse no injector.
Old 03-12-2011, 10:14 PM
67goatman455's Avatar
added to my memory bank, thank you. high res is for the coil i take it?
Old 03-12-2011, 10:22 PM
I checked them with the nous light...there getting signal...the opti only has 1000 miles on it....but it was from autozone came with the car
Old 03-12-2011, 10:26 PM
WS Sick's Avatar
Pretty much for that and the timing itself.
Old 03-12-2011, 11:08 PM
jester1614's Avatar
if your checked every one with the noid light and they all are getting signal, then they are either clogged/broken, or are getting no fuel to them
have you checked for fuel pressure at the rail?
Old 03-12-2011, 11:11 PM
henry172's Avatar
If you find the injectors or bad I can sale you a set of used stock injectors cheap.
Old 03-13-2011, 10:17 AM
I ohmd all the injectors. There ok ....I'm going to check the rail next and see if its clogged
Old 03-13-2011, 10:49 AM
Ok pulled the injectors.. they are spraying....I think the opti could be bad it has spark and fuel...but it wont fire.
Old 03-13-2011, 10:50 AM
RamAir95TA's Avatar
Plug wire order?
Old 03-13-2011, 10:54 AM
There right ...
Old 03-13-2011, 10:55 AM
Is the accel opti any good??
Old 03-13-2011, 10:57 AM
RamAir95TA's Avatar
Absolutely not. It's one of the worst, if not THE worst.
Old 03-13-2011, 10:58 AM
no, not at all. chandlermotorsports seems to be the way to go these days
Old 03-13-2011, 11:06 AM
I really can't spend 500 on this car to get an opti... remans are 120 but I'm sure there junk too....ill check out the Chandler ones
Old 03-13-2011, 11:10 AM
The Chandler is only 135 bucks....ill probably order one then. Was about to run to Jegs and buy an msd
Old 03-13-2011, 11:20 AM
RamAir95TA's Avatar
There is no benefit with an MSD over a stock, cheaper AC Delco opti. The less expensive optis are hit/miss with reliability.
Old 03-13-2011, 01:38 PM
Know anyway to test an Optispark To Know if it is bad??
Quick Reply: 95 trans am injectors not pulsing...
