Thoughts on BRP swap kits for GM A-body conv?
I was going to piece things together, but I see that BRP now has a complete kit for a LS engine w/T56 for convertibles including tranny crossmember. I could fab up everything but doubt it would be as nice and theirs I hope would make everything work together the first time.
Any thoughts on their kits? Anybody ever use a complete kit on an A-body? A convertible a-body?
Thx!
Thx!
The H3 / LH8 pan will hang down pertty low.. CTS-V is not bad, that is what I am runniing (it has it problems on pan clearences also ). The BRP sets up there engine mounts a bit high due to the H3 pan.
the do make a complete setup and if installed as directed, is an easy drop in.
Hi there, I've actually bought a kit for my 72 Coupe - about to trial fit the motor and have the CTSV pan conversion. Will update you how it goes - probably about 2 weeks away - awaiting some powdercoating bits back first
I would have purchased the brackets also, but the price wasnt realistic. Ive got a MIG, Torch, Drill press and 1/4 plate. Paid 12 dollars for the poly bushings. I havent got the tranny mount yet though, but im sure it isnt too expensive. I think its a great kit, but i think its only worth half what they are asking for it.
giver dude, I had their 1st gen kit. Mine works great, they only improved on the design. I'd run the camaro pan though, my car is pretty low and I am happy that I went camaro pan. any more hang down and that bitch would be leakin some oil!
I also have there kit. Im using an lq4/4l80 engine combo and it set in there real nice. No issues with power steering or ac pump. The LH8 pan does hang about 1 1/2" below the cross member so I welded an angled skid plate to it to help. Mines not running just yet so no road stories to tell. It does have Eibach lowering springs in it tho. the headers hang a little bit lower so if you hit your going to get them also....Others are right, does seem a little $$ for what you get...But it does save alot of trial n error fitting it up...
Rick
Rick
I may have had an exciting "tug" on the streets once upon a time, big bump came up and my car bottom'd out, hit the crossmember pretty good, threw some sparks, and no oilpan damage, Camaro pan I suggest LOL
a, abody, body, brp, chevelle, conversion, convertible, crossmember, gm, issues, kit, kits, ls, performance, swap, t56
