400+ rwhp from stock bottom end
Hey guy I was on ls1lt1 but i noticed this site has alot more people on it so i figured i would try for advice here.
I got 3k to spend and am trying to get over 400rwhp, but 430 is optimal
I am not going to change up the bottom end so here is my plan so far..
since on im budget im gonna try and get everything used... almost everything
--ported heads- either send in mine to LE or AI, or buy a used set of ported trickflows or somthing...from ebay or this site
--58mm throttle body with the intake man. ported to 58mm opening as well.
--ARP bolts-new
--30lb for red tops
--either Granatelli or racetronix 255 fuel pump
--gasket kit
--custom grind cam... unless one of you have a suggestion of a cam that makes this power at or under 6300
now my questions are...
i know i need 1.6rr, pushrods and guideplates... I know about the rockers but im not sur about the pushrods and guideplate, like what length and what is good. so maybe some part numbers that would work with my heads and motor?? like i said i dont know alot about that area...
will the stock valve covers fit the 1.6 rr with the larger cam?
andd is this the completelist of stuff i would need to do the head and cam swap, or should i do little things like timing chain?
I have all the supporting mods like built trans and full bolt ons. and the water pump and opti is new, along with a 500 horse radiator.... so im just working on the motor now
thanks
--ARP bolts-new
--30lb for red tops
--gasket kit
thanks
Have AI or LE get you cam for what ever heads you end up with. Pushrods length will depend on the heads if they have been milled, you may or may not want to do pistons and or rings. A good tune will be key to making the numbers on a dyno but what are you using it for? Yes do a chain at the least. May want to go with racetronics delphi 32lbers. they fit a lot better and make sure they are flow matched so you get nice even fuel to make that power.
This is going to be a street car.... just something fun to play around with my friends with...
Ill look into the racetronixs... i just have so many people telling my good things about the red tops...
and if im guessing the people at LE or AI can tell me the proper pushrod length after they have ported it?
is that all i would need to make the head a complete package? the rr pushrods and guideplates?
also the valve covers? will stockers fit?
You have to cut the braces in the valve covers
k well im a fabricator so that should be easy.... do the braces run down the length of the cover? like front of the engine to back?
I think i have this build totaled to around 2700. sound about right?
There are write ups and national magazine write ups with pics on this site and others about how to mod those valve covers to make them fit. just google it and you should find some. I never get to hung up on dollar amounts because what ever I think it's gona cost... it usually cost double.
http://cgi.ebay.com/ebaymotors/Advan...mZ110664764774
There is a set of AI heads I came across on ebay.
im looking to start this build in the beginning of may... if i had the money right now i would spend it to save money... but i dont wanna risk it incase something happens... but that seems like a good sale
speeddemon... maybe you can help me with my set up then... cause as i said 430 is where i wanna be lol so i would want your set up...
did everything i list you do? im trying to be on a budget so anything i can go without i would be happy
We are lucky to have a couple of head porters catering to LT1s, I thinnk either will be money well spent.
I have used red tops on ly LT1s and l98s for over 20 years without a problem.
@ramair-- i can agree with that... everthing that i have planned on doing to my car has never turned out to what i "wanted" to pay..... but im a planner.... cant help it
I don't agree with this at all. All my car has is normal off the shelf parts. Hell I don't even have an electric waterpump or ported intake manifold.
