what transmissions can be put in a 93 firebird lt1??
Old 03-24-2011, 07:18 PM
93beast's Avatar
Default what transmissions can be put in a 93 firebird lt1??
im looking to swap my stock 700r4 automatic transmission and im wondering what are ALL the kinds of ttransmissions you can put on the lt1. I know the t56 and the th-350, but what else can be bolted on there?
Old 03-24-2011, 07:28 PM
96TransAmboosted's Avatar
turbo 400, 4l60e
Old 03-24-2011, 07:29 PM
3DFORMULA's Avatar
With the 700r4 having a 3.06 first gear I would say, think about just doing a heavy duty/upgrade rebuild.
But there is the 2-speed automatic powerglide and the th400 also.
Old 03-24-2011, 07:36 PM
hashtagBMW
Speed Density's Avatar
Originally Posted by 96TransAmboosted
turbo 400, 4l60e
TH400, not without a different crossmember, dipstick, driveshaft. Its not a direct replacement, it takes fabbing.
4L60e, not at all.
Stock 93's are 700R4/4L60. TV cable adjusted, no electrical reference.
Old 03-24-2011, 07:37 PM
nitrous2fast's Avatar
200r4
Old 03-24-2011, 10:09 PM
James Montigny's Avatar
You can do the 4L60e, but you'd have to run a newer harness and PCM.
Works out well for guys who want to do 24x.
You could also just run a stand-alone trans computer, but they're not cheap.
But yeah, as far as bolt-up auto solutions ... you're best bet is to stick with the 4L60.
I'll have one for sale soon (only 60k miles), I'm going 4L60e
Converting to a manual isn't exactly painless, but it does get you away from some of the compatibility issues.
Originally Posted by nitrous2fast
200r4
Different driveshaft and crossmember
Old 03-25-2011, 02:01 PM
Moderator
BizZzatch350's Avatar
93s being ECMs still, not PCMs like 94+, the computer doesn't care what trans is in it. You could run a glide with a 5K stall for all it cares. Just like mentioned any thing with an "E" will need a trans controller or similar.
Old 03-25-2011, 04:12 PM
One thing to point out (that a lot of people seem to miss) is that you really
need a setup that can make enough power to get a car moving with a glide.
Most H/C cars are going to be turds behind that first gear even with a big stall.
Quick Reply: what transmissions can be put in a 93 firebird lt1??
