Cams to pass emmissions
I don't know much about what the numbers stand for in different cams. What I have learned from my search is that I need a cam with 114 lsa or higher to keep my car emmissions legal. Is this correct? What is the most aggresive cam I can run and stay legal?
Also, if you have a link to help educate me on what the numbers mean, post it up because I found nothing.
Re: Cams to pass emmissions
By the way, mods are in sig...just looking for a car to be a lion at the track and a kitten on the streets. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thunder Racing's 220/220 114 cam should pass emissions and maintain good drivability. You may be able to go a little bigger, but the 220 has a good track record of passing emissions and on a 114 LSA has decent street manners.
If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions.
If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions. [/QB][/QUOTE]
Sounds pretty close to the Hotcam
LS1Tech Administrator
Received 1,493 Likes
MTI B1 cam has also been proven to pass emissions by more than a couple members. It's a 221/221//.558/.558//114lsa.
I have this cam. Excellent street manners, while still having a nice beat at idle @800rpm <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 89ws6formula50:
[qb] If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Sounds pretty close to the Hotcam </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not really, the Hot Cam and this one are at two opposite ends of the spectrum. The Hot Cam will give you a real nasty lope with it's 218/227 duration and 112 LSA. Not trying to put you down, I would just hate for someone to think these two behave alike.
<small>[ February 27, 2003, 02:18 PM: Message edited by: Cal ]</small>
