stock fuel pressure for an LQ9
For a newbie that doesn't know jack about the LS platform I fricken LOVE this forum!!! Rarely need to post!!! I've made a couple threads for info I couldn't find but simple threads like this have been a savior for answering questions I've had!!!
I have a LQ9 (with a cam if that matters), and it has been running a little rough right off of idle. It seems to clear out fine at WOT.
The motor is in a jeep, and nothing has been changed in a few years and it just started doing it last weekend. No codes thrown. Fuel pressure is 60 psi with just ignition on, then it drops to 52 when at idle, then it drops to 50 when I rev it a little.
I am still using stock fuel pressure regulator, and am using a Airtax E8248 pump, and new fuel filter.
I did pull the vacuum line to the regulator, and it jumps back up to 60 psi.
Also, when I kill the ignition, it holds the pressure on the gauge.
Any ideas? Pump? Regulator?
Restricted User
I would say fuel filter but you say its new.
Has it been tuned for the cam? Have you tried changing plugs?
Changing plugs this weekend, to see if that helps.
Restricted User
Yes. That's what the vacuum line hooked to the regulator does. Vacuum pulls down the fuel pressure at idle.
