Powersteering pump making loud noise only on startup.
Old 02-18-2004, 12:49 PM
Scalpel's Avatar
Default Powersteering pump making loud noise only on startup.
For the past two days now when I start up the car the power steering pump (at least that's where it sounds like it's coming from) makes a very loud whirring/crackle sound that will disappear about two minutes after driving.
Is the pump on its way out? Fluid level is fine.
There's no increase in steering effort, etc.
Old 02-18-2004, 03:28 PM
frnknjp's Avatar
Mine does the same when the temp is below zero. No problems yet.
Dave
02WS6
Old 02-18-2004, 04:17 PM
DARK AGE 53's Avatar
Could it be the belt and not the pump, something worth trying is Lucas Power Steering Stop Leak. I used this on a 99 SS I once owned with excellent results, removed the fluid with a turkey baster and added the same amout of Lucas.
Al
Old 02-18-2004, 04:25 PM
Scalpel's Avatar
The belt is new and tension is good so I'm confident the belt isn't the issue.
Old 02-18-2004, 04:40 PM
Idler pulley?
Old 02-18-2004, 06:24 PM
Scalpel's Avatar
It does it randomly, no rhyme or reason to it, it just happened to occur on start-up the past two times.
Old 02-19-2004, 07:40 AM
STRIPSTAR's Avatar
My car was doing the opposite, it would whine when it was hot. I ended up getting everything replaced including the rack. Its fixed now but the factory power steering is a major weak spot on these cars.
Old 06-21-2005, 07:52 PM
ProjecT 9's Avatar
mines whining really loud right now, i replaced the actual pump, but still have the sound there....anything else i could change out to try and get rid of the noise? mine is constand, and gets louder the faster the belt spins...its really annoying...i thought maybe it might be the altenator, but im pulling good voltage...im stumped..
Jon
Quick Reply: Powersteering pump making loud noise only on startup.
