aftermarket torque arm and brake dive...
Moderator
Yeah, brake dive is soft front springs and high
center of gravity (forward weight transfer and
spring compression). The torque arm has no
authority at all over this.
Dropped suspensions are usually higher spring
rate and reduce CG height.
Where it does matter is in brake hop. A funky
short arm that is a launch monster might put you
into that if the instant center is pushed too far
off from original. If drag torque on the rear makes
it lift strong then you might lose some rear braking
traction.
Any stock-mounted, or near-stock fore-aft front
mount located TA shouldn't affect things other
than with added robustness.
traction.
Originally Posted by Assassin
ehh, not really, dropped suspension will make the biggest difference
