Cold Air Intake Question?
Hey i know that most if not all of the impala and monte carlo owners are running cold air intakes. But the question i have is what is a better cold air intake to go with, K&N, Cold Air Inductions, or the ones ebay have for under 100 bucks. Im looking to install one but i would like some feed back on which one iss a great buy and a good product.
In order of quality:
1. CAI
2. K&N
3. Ebay
The Cold Air Inductions box completely seals the cone away from the heat of the engine bay; and the intake arm is not plastic like the K&N
The K&N is an open box, all plastic, and arguably somewhat more prone to heat soak than the CAI
Ebays are junk IMO they are not even true cold air intakes because they do not seal off the cone from the heat of the engine bay. You'd get the same result from removing the stock airbox and putting a cone on the end of the intake arm.
As a fourth option, you can make a home-made intake from parts from home depot, although generally there is no data to back up any results of a home made system.
1. CAI
2. K&N
3. Ebay
Make your own
It's not hard at all to make your own CAI. Some aluminum, lexan, hardware, a cone filter and silicon elbow. I used matte board and masking tape to make a template, transferred the pattern to sheet aluminum, some bending and pop rivets and a little patience is all it took. This is my third home made CAI, I made one for my 2001 SS, 2005 GTP and now my 07 SS.
1. CAI
2. K&N
3. Ebay
1. CAI
2. K&N
3. Ebay
hey cully, we going to go to a car show when it gets warmer ?
is there enough room between where the computer mounts, the fender and where the headlight sits without having to modify anything or did you just sneak it through all that ?
ill agree with cully on that one ... the CAI intake is awesome ... worth every penny - but tappeter's seems to accomplish the same thing, so i guess if you have the ability and resources- thats the way to go ...
And another advantage of the CAI is that it mates to a certain aftermarket hood
