replace clutch but its really hard to put the gears in
hey guys and gals i just replaced the clutch on my 99 transam with a monster stage 3 kit,new master,new slave,new bolts,did the drill mod and put the speed bleeder on it.tbut the gears are very hard to go in; i been bleeding it like crazy but it doesnt help what could be wrong, the car moves a little when its in first gear with the clutch all the way pressed in.when i drive it the gears are alittle hard to go in but they go in.
On flat ground with the car in first gear clutch pedal pressed to floor rev engine to 5-6k. Does the car creep forward? Or on a hill car not running in first gear slowly push the clutch in, where in the pedal travel does the car start to roll?
You dont need to rev the car to 5 or 6k... Just put it in gear and see if the car moves.
If you cant afford the tick then this thread might help you out.
https://ls1tech.com/forums/manual-tr...r-writeup.html
Either way if you keep driving the car like that your trans will be needing a rebuild soon...
