MAF housing porting
Old 02-19-2004, 07:01 AM
Q8CamaRo's Avatar
Default MAF housing porting
i finished porting my stock MAF .. then i checked my car for any code
i found two codes
1-maf high input circuit
2 maf high input circuit
can any one help me what is this?
i really will appreciate .. thanks
Old 02-19-2004, 08:21 AM
Moderator
jimmyblue's Avatar
Those sound like the MAF electronics are
putting out an overrange (high) output
frequency. MAF porting should mess you up
but in the other direction, and not to a code-
setting degree. Did you do this with the
electronics still in place? If so you might
have smegged one of the little sense
resistors?
All together now...
"ported MAF... Baaaddd".
Old 02-19-2004, 08:32 AM
Q8CamaRo's Avatar
resistors?
All together now...
i`ve done like what www.installuniversity.com says
i have another maf .. do u recommened to descren the maf?
Old 02-19-2004, 10:30 AM
slow's Avatar
reccomend a stock one. with screen.
installuniversity information is old, and that is the one mod i do not reccomend from that site. the rest is good information.
Ryan.
Old 02-19-2004, 02:22 PM
dissonance's Avatar
agreed if you have a4 dont port the maf. m6 maybe?
i have had a home ported, TR ends and 85mm maf and none of them help me... only hurt my times.
but not all cars are the same... if your running really rich then yeah ported unit might help only becuase it brings the a/f ratio closer to stock...
Old 02-19-2004, 03:41 PM
slow's Avatar
modifying a sensor to get the output you want is "ghetto tuning" plain and simple.
we have the technology, do it right
Ryan
Old 02-19-2004, 04:08 PM
98blackSS's Avatar
Ryan
Amen to that.. leave the maf alone. The only thing you'll gain is headaches. The stock MAF will support more flow than you realize The 1-2hp gain from this mod is not worth the trouble.
