ls1 ps pump too much pressure for IROC box?
I was wondering if the ls1 pump will be putting out too much pressure for an IROC steering box, idk if i need a pressure reducer or not. any help would be appreciated
I was planning on just switching hoses and being on my way!
I am using the stock LS1 F-Body pump on my stock Chevelle box. it work ok, but every once in a while I would get a small lock up under throttle and while turning (auto-x). I was about to start digging into changing the pressure valves and all.
But I put a cooler on the return line and the lock up disappeared. I would recommend trying a cooler to everyone.. 1200+ psi creates a lot of Heat !.
