Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
- Camaro and Firebird: How to Remedy Stuck Clutch Pedal
Step by step instructions for do-it-yourself repairs
Clutch sticking to the floor after hard acceleration problem solved!
The notorious problem of the clutch sticking to the floor after hard acceleration is far too common! Something I experienced every since I bought my latest f-body. I believe thanks to danbo313 there is a solution to this.
Solution:
Up at the top of the clutch pedal there is a "U" shaped spring, known as the clutch pedal return spring. After removing this spring my problem of the clutch sticking to the floor was finally resolved (I removed the spring and did not replace it just totally did away with it) Now at 3:35 A.M. I believe this is the solution for most everyone out there that is having this issue, although for some it may be the master cylinder I recommend trying this first. I at first thought it was my master cylinder but after recieving a message on here from danbo313 about the clutch pedal return spring, and doing some more research I figured I'd remove the spring and see if that would solve my problem before spending the money on the Tick M/C. Believe it or not my car now goes into gears a lot easier and after ragging it threw 1st-4th gear at 5500 rpm shifts the clutch did not whatsoever stick to the floor.
If your having this issue I strongly reccommend removing the spring before spending the large amounts of cash on parts that are not possibly necessary.
If this doesn't solve your problem, because I'm not 100% sure this is every ones solution, I'm sorry. But it would never hurt to try this before spending the cash. It worked for me and after doing my homework have seen that it worked for many others as well without replacing the slave or M/C. f
Solution:
I would say replacing the master cylinder is what would fix the problem since I just did this with one from Tick performance, I also did take the spring off as it was recommended per the install instructions. High rpm shifting all day now, ha ha.
i tryed it and fixed the prob... no more sticking at high rpm....sweet...... now i know i still have to buy a new clucthmaster cly.....but for now im loving this.....
Sometimes (key word) the return spring is the problem. It was for me. On mine, the spring was so weak that the ends of it would catch on the bracket. Now on mine not only would it stick but there was a grinding sound every time the pedal was depressed.
My fix - zip tie around the spring. 8 months later no sticky clutch pedal. (every case is different though)
Mine popped off under warranty, and I had the dealer put it back on. Popped off again and I stuck it in a parts caddy and later threw it away. That was in 2002. I have never had my clutch pedal stick to the floor.
That's no proof, of course, and I'm not trying to talk anyone out of a better aftermarket part, like Tick, but it's a clear first step and free .
BobP
BobP
Well, the problem is definitely the master cylinder. BUT, the spring helps you push the pedal to the floor to reduce fatigue. When your master is going back it loses pressure, especially after high rpm shifting. Removing the spring allows it to return because it remove that little bit of extra downward pressure on the pedal. It's not "solving" the problem, it's just masking the symptoms. It's like saying, the bandaid fixed the 3" gash on my leg. Stitches would fix the gash, the bandaid just makes it so that it's not quite as bad. Stitches = tick master cylinder Bandaid = drill mod and !spring.
The problem is'nt the master or the spring.....The problem is and has been the clutch. I have'nt had this problem since I did my own clutch set-up. The pp just ain't strong enough to keep the fingers out thus when you depress the pedal it either can't get there or it don't have enough travel to push the pedal back.
The spring makes it easier to push the clutch peddle in so when your peddle gets stuck on the floor that spring is working with the problem so removing it will help the peddle not stick or not stick as much. I plan on taking mine out but also plan on buying a tick when I have the extra money
Mine broke while I was driving about 3 years ago, I never put a new one on. A Tick master will fix your sticking pedal problem; they actually recommend to remove the return spring during the install of their MC.
