Notices
rear brakes any shape!
Old 04-11-2011, 02:54 PM
LETZRIDE's Avatar
Default rear brakes any shape!
Looking for a set of brakes for a 4th gen camaro along with the backing plates.
Swapping from drums to discs
Let me know what you guys have.
Thanks,
Mike.
Old 04-11-2011, 04:31 PM
VinR1's Avatar
I have an almost complete drum-to-disc conversion for a 3rd gen fbody... should fit fine on your rear. Brackets, bolts, calipers, new pads, rotors, and some misc lines. PM me your # or email and I can send some pics. $175 plus shipping
Old 04-12-2011, 09:13 AM
LETZRIDE's Avatar
pics recieved thanks....morning bump
Old 04-12-2011, 09:26 AM
lemons12's Avatar
I got quite a few brake pads.. might have some rotors as well.
Some pads are brand new, some slightly used. Rotors will have to be turned I'm sure if I still have them.
Let me know if Interested.
Old 04-12-2011, 01:07 PM
LETZRIDE's Avatar
the main thing I probably need is the backing plates and calipers...everything else is pretty cheap to replace...
Old 04-12-2011, 05:27 PM
therealcreeper's Avatar
I have ls1 rear slotted rotors and calipers, PM me if interested
Old 04-12-2011, 05:28 PM
lemons12's Avatar
Anything I have I will sell for heap, its just taking up space.
Just let me know if u want to pick any of it up.
Old 04-12-2011, 08:13 PM
davidz28man's Avatar
Default brakes
pm ed you i have anything you need off my rear end its a 2000 z28 100 % complete just tell me what you need.
Old 04-13-2011, 10:21 AM
LETZRIDE's Avatar
I just found out that I should be getting the calipers and brackets off of an LT1 car...otherwise I may need to change my master cylinder due to more fluid usage...
alot of good offers from Ls1 guys though...thanks.
Old 04-13-2011, 11:43 AM
Brakemotive's Avatar
FYI they use the same diameter master cylinder bore (1") so you should be OK there if you still want to use the LS1 rears.
Old 04-13-2011, 04:43 PM
LETZRIDE's Avatar
hmm...I've heard they are 2 different part numbers...I'll have to double check with GM tommorrow to be sure.
Old 04-16-2011, 10:18 AM
LETZRIDE's Avatar
bump...
Quick Reply: rear brakes any shape!
