LY6 Valley cover question
Old 04-14-2011, 02:42 PM
Prorac1's Avatar
Default LY6 Valley cover question
I have a 08 LY6 6.0 (Essentially an LQ4 with L92 heads). I was under the impression that all GEN 4 motors made after 2006 had the LS6 style valley cover? Mine has a flat valley cover with no venting provisions. I am converting this motor over to carb with an edelbrock vic jr. I have a fitting on the front of the pass side valve cover and a fitting on the back of the drivers side valve cover, but nothing on the valley cover.
My options are A-switching to an LS6 valley cover, B-using my existing valve covers and running them to a catch can, and than back to the intake, or C- run aftermarket valve covers with a breather in one and a fitting in the other running a catch can than to the intake.
Is it possible to simply run an inline filter (like one on a air compressor, a small inline clear one) instead of a catch can? The capacity would not be as large, but it would work in theory? Any insite is appreciated. Thanks, Eric L
Old 04-07-2013, 01:04 AM
linicklo's Avatar
yes i know im a grave digger, but what did you end up doing ???
Old 04-14-2013, 01:07 PM
Jimbo1367's Avatar
I am wondering myself.
Old 04-15-2013, 01:53 PM
Prorac1's Avatar
I ended up running some Ebay valve covers with a open element breather on the pass side, and an 8AN fitting on the drivers side running to a breather tank. That way I can monitor how much oil/water im accumalating. And I can switch it around and try differant combonations of breathers side to side. I just left the stock LY6 valley cover in place. Eric L
Old 04-17-2013, 11:45 AM
SlvrSierra4.8's Avatar
I have an ls3 valley cover for sale that would solve your issues, let me know if your interested
Old 04-17-2013, 03:50 PM
Prorac1's Avatar
Just for future "gravediggers", lol, Does the LS3 valley cover have the LS6 PCV set up AND the o rings for the DOD ports? Eric L
Old 04-17-2013, 07:39 PM
Yes, to both questions above
Old 04-18-2013, 11:40 AM
RENE'S RAGE's Avatar
What is the LS6 PCV set-up?
How is it plumbed?
I had an LS1 now I have a LS3.
Trying to figure out how to plumb it.
Wanting to run breathers on the valve covers,
And not wanting to plumb back to the intake.
Quick Reply: LY6 Valley cover question
