99 5.3 with gto 6.0 heads and cam ??
Old 04-15-2011, 11:14 PM
5.3 cutty's Avatar
Question 99 5.3 with gto 6.0 heads and cam ??
i have a 99 iron block 5.3 and i came into a set of ls2 heads and cam .i know they cam off a newer gto but i want to know will these 6 liter parts will fit my 5.3.....any info will be helpful thanks.....
Old 04-15-2011, 11:24 PM
the_merv's Avatar
Yes. I would find a better Cam..the LS2 Cam will NOT work without the LS2 Timing Cover , Sensor, & Gear.
Old 04-15-2011, 11:34 PM
5.3 cutty's Avatar
ls2 cam for sale obo lol!!!!
Old 04-15-2011, 11:39 PM
5.3 cutty's Avatar
Old 04-16-2011, 09:01 AM
TurboLark's Avatar
Using the ls2 heads will lower your compression ratio a bit i believe. the 5.3's only had a 61cc chamber.
Old 04-16-2011, 12:47 PM
5.3 cutty's Avatar
So is it even worth the hassle to use the ls2 heads with a mild cam
Old 04-16-2011, 02:34 PM
v8envy's Avatar
not really, if you really want better heads on your 5.3, go find some 243 or 799 casting heads they are identical to ls6 heads the ones on the trucks have different valves but still perform great. Sell the ls2 heads and cam, you can't use that anyway. find a used Ls6 cam and springs and you will have a good running low budget 5.3 that can make 380 hp
Old 04-16-2011, 02:41 PM
bigmandengo's Avatar
As far as I know ls2 heads are 799s
Old 04-16-2011, 02:47 PM
Jimbo1367's Avatar
LS2 heads(GTO) are 243s
Old 04-16-2011, 03:34 PM
1989k1500's Avatar
Like said you cant use the cam with out a bunch of other parts, which makes it completely not worth it.
I would sell the heads too.
I think a 4.8/5.3 head has a 59cc chamber.
Old 04-16-2011, 03:35 PM
1989k1500's Avatar
You dont have a regular 5.3 like his 99 5.3. Yours is a L33 and has flat top pistons and 799 heads stock.
His 5.3 has dished pistons.
Old 04-17-2011, 06:30 PM
v8envy's Avatar
ahhh yes good point, I was pretty sure the 6.0 Ls2 had bigger chambers I should have done my homework.... ok well if he has dished pistons keep the 243/799 heads and put a turbo on it to compensate for the loss in compression...lol
Old 04-17-2011, 09:56 PM
TurboLark's Avatar
There is the solution right there!!
Quick Reply: 99 5.3 with gto 6.0 heads and cam ??
