Huge situation with exhaust!!!!
well i own a LT-1 Camaro, i have a rattling problem coming from my exhaust, my passenger side header is hitting on my stock k member and making a really ba drattle, it also dented my header. i was going to switch out my stock k member for an after market k member until i was told that the k member will not stop my rattling noise and will still hit my header. i was told that there is no fix to this even if i get an after market k member? does anyone else have this problem or have a solution to it?
Were i got my info from my boss because he has tried everything and he knows a lot about these types of cars.
well i have not checked my engine mounts but they have not been changed since i have owned the car. but i mean if they haven't been changed then if i change then then it would only move my engine up a little bit. i do not believe it would fix the problem but i will give it a shot and look last them
I don't understand. If they are worn out it doesn't just put the engine back where it is supposed to be, the engine rocks less as it is running. For the LS1 cars we almost all install poly motor mounts with our longtubes so they don't bang around.
What brand headers do you have? Are they touching the K-member with the engine off?
