New Under Axle Exhuast Pics!!
New Under Axle Exhaust Pics!!
Okay all I am trying slowly but surely to get my site completed, still have a long way to go, so don't dog me out too bad. CHECK OUT PICS IN SIG!! Please leave opinion in guest book!!
Thanks all!
Thanks all!
Helped out a TON!! Night and day difference. Plus, you can't see the turn downs unless you are way back and actually looking for them. And the lowest part of the reducer setup is not the lowest part of the system. Sounds even better now. Sound to come soon!
From the point where it turns to go up in the back, which would be the lowest point, it is close to 5" from the ground. The X-Pipe that comes out of the drivers side header is 4" from the ground. I also have the hangers in the back bolted for ease of maintanence. I was just surprised when I got it off of the lift at how good it sounded, and the fact that you really can't see it from the rear due to how low the F-Cars are anyway. My car is stock height by the way. Hope this helps.
Dothan, AL huh? I live in Chattahoochee, FL about 1 hr away. When I get my long tubes I want a pair of Flowmaster Delta Force 10 series mufflers (6.25" long) where the cats are, and no crossover. Then oval pipe turned to exit at a 45° angle in front of the rear tires. Think this guy could pull that off?
Or I could go under the axle with the tips at the same angle you did, only with 3 inch tips just poking out from under the rear facia ala classic muscle cars.
Options, optins, options......
