Low Numbers or Does It Sound Right
Got on the dyno yesterday and I put down 417 hp and 386 tq. Mods are a 228r cam on a 112 lsa, Patriot stg 2 243 heads 11:1 comp, fast 102 & throttle body, 85mm maf slp ud pully and tsp 1 7/8 headers no cats. Im on stock injectors and my a/f was good but they are pushing 99% duty cycle (thats my next upgrade)
I did dyno on heavy Torque Thrust Wheels but I didnt think that would affect it that much. I know it might be my heads that are killing the power but I thought I would be at 430 easily and above 400 tq with my mods.
cars an m6 with a monster stg 3 clutch & stock rear
looks a little low,my car is very similar except i have 1 3/4" headers with cats,my cam is a 228/230 on a 112,and a fast 90/90 and i put down 441 and 402 tq.I run 25* max timing on my setup,do you know what your max timing is.
Just as a reference, my car made 427rwhp & 395tq with the following mods which are not to far from what you have. The dyno was RPM`s in DE.
228R 112lsa
2.5 5.3 TSP heads, ported FAST 92, 1 3/4 headers(no cats)
MWC 9'' 3.70 gear
Circle D 4C stall (3600-3800)
I think your numbers are in the ballpark, but like you said already, I would look at upgrading injectors.
228R 112lsa
MWC 9'' 3.70 gear
Every dyno can be different, if you don't have a before dyno to compare to there's no since in comparing numbers to others who haven't been on this dyno. The Patriot heads are holding you back imho, that and you need to get some better injectors in there asap to ensure you're not going lean in different weather conditions, which can effect duty cycle.
