Notices
NEED: Truck intake, injectors, fuel rails, cable TB...
Old 05-11-2011, 04:09 PM
rockcity's Avatar
Default NEED: Truck intake, injectors, fuel rails, cable TB...
My rig caught fire and nearly burned to the ground! Lucky part is that it was a fire in the driver/passenger area and the motor sustained minor damage where I need all new parts that had plastic on them.
So, I need:
truck intake with stock injectors and fuel rails for LQ4
drive by cable TB (mine may be OK but not sure yet)
engine harness
ECM
All sensors!
coils with wires
Lokar throttle cable
Lokar Turbo 350 kickdown cable
oil cap
I'm sure there are other things I'm forgetting...
Shoot me a PM with what you have and price so I can get this thing back up and going!
I'm in NC and I'm sure I'll need some or all of this shipped!
Thanks.
Rob
Old 05-11-2011, 06:44 PM
nobreaks254's Avatar
I have an intake with fuel rails and stock injectors off an 04 lq4 for $50 plus shipping. I also have the TB but it may be sold.
Old 05-11-2011, 10:09 PM
squee's Avatar
Do you prefer truck or f-body coils? I have a set of f-body coils and brackets if your interested.
Old 05-12-2011, 08:41 AM
WickedRamAirWS6's Avatar
I have lq4 intake with rails and injectors.
Also have truck coils and brackets. Pm me
Old 05-12-2011, 09:09 AM
rockcity's Avatar
I'm not sure the difference between the F body and the truck coils. I had truck and would assume to just go back with truck coils unless there is an advantage to the F body coils and they are affordable
Old 05-12-2011, 09:15 AM
94'BLKBRD's Avatar
Search d585 truck coils, they make more hp an tq than the f-body coils
Old 05-12-2011, 09:28 AM
Baltimore Whore
Mangled03gmc's Avatar
I have 7 OEM plug wires.. Yah it's not 8 but, better then none lol.. PM me if your interested..
Old 05-12-2011, 09:29 AM
rockcity's Avatar
well then I def. want the truck coils back on there
Old 05-12-2011, 11:23 AM
94'BLKBRD's Avatar
Pm sent for coils/plugs
Old 05-12-2011, 04:04 PM
rockcity's Avatar
Found ECM and coil paks and wires.
Still need everything else...
Really looking for a cable throttle body as well!
And, if someone has a dip stick handle, mine is melted pretty bad so I need one of those. I know I can get it at the dealership but they want like $28 for it with the stick... I have an old one but its got a small crack in it so looking for one thats better
Old 05-13-2011, 01:20 PM
rockcity's Avatar
sourced an intake, injectors, MAP sensor, throttle body and sensors, knock sensor, oil cap, and dip stick.
Still looking for a harness, cam sensor, crank sensor, water temp sender, and O2 sensors...
Old 05-14-2011, 09:50 AM
NastyC6's Avatar
^ i offered my sensors to you, PM me if you still want them.
Quick Reply: NEED: Truck intake, injectors, fuel rails, cable TB...
