Help with cam for ls2 shortblock w/215tfs, fast 102/90
I'm having trouble deciding on either using my current cam (not installed) 228/230 585/585 112, or going with something slighly bigger or a custom cam? My set-up consist of stock LS2 shortblock, 215 tfs heads, 1.7 YT, ported fast 102/90, kooks LTs ory, M6, 12 bolt 3.73s.
I'm not trying to build an all out high HP build, just an all around good street performer with good street manners. Thanks in advance
I still havent picked a cam yet. I was thinking of going with an EPS cam in the 230/234 range. But a buddy mentioned Isky cams. Is anyone running them? What do you guys think of Isky cams for LS engines. I'm getting a new daily driver so it's mainly going to be a weekend/fun car.
Turd Gen Guy
yeah it took me almost a month to recieve my cam, and my heads are t.e.a. ported shaved 317's, the 230/238, fast 102, full exhaust and the 6 speed.. makes 463/432.. recently went back and it made 449.7 in the flordia 98 degree heat. your car should make 475 easy with the same ish camshaft
yeah it took me almost a month to receive my cam, and my heads are t.e.a. ported shaved 317's, the 230/238, fast 102, full exhaust and the 6 speed.. makes 463/432.. recently went back and it made 449.7 in the flordia 98 degree heat. your car should make 475 easy with the same ish camshaft
