So this is what my clutch and inside of tranny looked like
Old 05-23-2011, 09:56 PM
porksoda's Avatar
Default So this is what my clutch and inside of tranny looked like
Sorry about all my threads the last couple days. Just figured you guys would like to see why my car wouldn't go into certain gears anymore. Miraculously though it still drove around and would go into all gears if shifted just right. How do you all think I should clean the transmission? I don't think I should pressure wash it and scrubbing would take forever!
Old 05-23-2011, 10:18 PM
GR33N GoblinM6's Avatar
you're not using the inspection cover are you?
mine looked the same, because of an oil leak, and no inspection cover. I got a new steel cover from ebay, very nice piece..
I cleaned my bellhousing and trans with "Brake Kleen"...i think i used about 3 or 4 cans on it.. i did clean the trans body with those as well, but its by far the best thing i used.. I also tried "Gunk" grease remover.. that sucked..
BALLSS's Avatar
pressure washing the tranny is fine. use a tail shaft plug.
simple green, brush and water will also work.
find source of oil leak....intake, rear main seal or tranny and repair
Old 05-23-2011, 10:26 PM
porksoda's Avatar
Actually the inspection cover was on. I'm thinking that is build up from when my intake was leaking. I fixed that last year though. I will be replacing the rear main though just as a precaution.
What do you guys think about the pilot bushing? Should I replace that too since I have it apart.
Old 05-23-2011, 10:27 PM
its a cheap $3 part.. why not?
Old 05-23-2011, 10:33 PM
DAVE00's Avatar
Yes, replace it.
Old 05-23-2011, 10:57 PM
IronOutlaw's Avatar
Spray It....
With lots of brake cleaner.
Old 05-23-2011, 11:17 PM
porksoda's Avatar
I'm probably about to go to the car wash and spray the tranny after I close up the shifter hole and driveshaft hole.
Old 05-24-2011, 01:14 AM
letsrun97z's Avatar
I'd also replace the input shaft seal it's 7 bux I had two clutches ruined because that seal and the rearmain. Also BBQ cleaner works the best out of anything
Old 05-24-2011, 06:36 AM
wrd1972's Avatar
Yeah take it to a self serve car wash. I did this the past winter when it was below zero. Lol.
Old 05-24-2011, 07:01 AM
88irocarmy's Avatar
I just did the clutch install and mine was also pretty dirty. Did the rear main seal while I was in there. I also did the wet-paper method for the pilot bearing (and it worked). Just like you I had broken springs that prevented shifting once the car was running.
Old 05-24-2011, 12:10 PM
porksoda's Avatar
Input shaft seal? Is that the one on the transmission around the shaft?
Quick Reply: So this is what my clutch and inside of tranny looked like
