8.8 drive shaft length
Just for future references in our system, you guy are using the stock length shaft but just putting the 4 bolt flange on the back (the Ford 4 bolts flange) correct ?
Hey guys I have my stock driveshaft with a crossover ujoint a or precision 355. Has the stock mustang 8.8 pinion but the flange yoke I have will not fit onto my new ujoint, does anyone know where I can get the correct flange yoke??
It all depends on the Ford flange, give me the dimensions of the flange you have. Ford has a few different joint sizes (i may also depend on the driveshaft, i know what the stock shaft should have but its possible its been changed is it steel or aluminum)
your shaft should have a plastic injected style shaft with a 3.6 wide joint sporting a 1-1/8 cap.
does your shaft have a 3.6 wide joint with a 1.063 cup ?
why done you just call 1-80--564-2244 ask for Frank, you dont have to buy it from me ill give the joint number so you can get it local.
Alright so my flange is 3.5" with 1.063 cup
And my driveshaft is 3.5 with 1.125 cup
The u-joint clip grooves on the flange are on the outer edge of the inside of the cup unlike the driveshafts
