Help! Anyone running a Spohn DSL Crossmember (part#405) with Eibach Sportline Springs
Old 05-25-2011, 10:00 AM
LSxWS.6's Avatar
Default Help! Anyone running a Spohn DSL Crossmember (part#405) with Eibach Sportline Springs
Was wondering if anyone is running the Spohn Adj Tq Arm with the DSL Crossmember for LT Headers and Y-Pipe(Part# 405):
http://www.ws6project.com/user_stor/...e.php?pID=2466
Im wondering what the ground clearance is becsause i have the flat DSL Crossmemeber;
(http://www.google.com/search?q=spohn...w=1345&bih=506 Part# 402)
because it says its safe for running Kooks LT's and good ground clearance for lowered cars. My car has kooks 1 7/8 and is dropped on eibach sportlines with 19" chrome c5z wheels so i was wondering if anyone has any issues with this. i want to run the other dsl crossmember so i can fit a custom true dual x pipe on the car and it just wont fit with the flat dsl crossmember. pics and help asap! thanks!
Old 05-25-2011, 10:48 AM
LSxWS.6's Avatar
bump need help asap so i dont leave a fellow member waiting on me to purchase the dsl cross member met for lt's and y-pipe!
Old 05-25-2011, 11:55 AM
LSxWS.6's Avatar
bump!
Old 05-26-2011, 10:49 AM
LSxWS.6's Avatar
h
e
l
p
Old 05-26-2011, 12:08 PM
LSxWS.6's Avatar
b
u
m
p
Old 05-26-2011, 02:03 PM
1BAD02WS6's Avatar
I have the UMI body mount tq arm and sportlines, the front mount is low. Very low, I wish I had the flat mount
Old 05-26-2011, 06:51 PM
LSxWS.6's Avatar
lol ill sell u my spohn flat mout if it will work for you haha only reason i really need to get the dropdown is because i gotta have a custom 3" true dual made to pass thru the crossmember and the flat one just wont cut it, its close to being able to do it, but not close enough. if i were to run a y pipe, even a 4" pipe would fit with the flat cross member. ughhhhhh lol how often do u bottom out with it?
Old 05-26-2011, 09:42 PM
1BAD02WS6's Avatar
I bottom out alot! I'm pretty sure if I got beer goggles and went hogging, the fat chick wouldn't be able to ride in my car....... But really I can't drive over a cola can on it's side
Old 05-27-2011, 09:05 AM
LSxWS.6's Avatar
lmaoooooo well i guess i wont be ablr to go hoggin with ya either with the fat chicks since we will both be bottomed out! lol well im guna run it to get the true dual made for the car then maybe have a local fabricator make me a crossmember thats tighter to the car and exhaust usiong the dsl and tq arm mount off the spohn setup. ugh so much bullshit with these cars and fitment!
Old 05-27-2011, 09:10 AM
atrain59's Avatar
I was lowered on sportlines and bottomed out on everything thing. It was on and off in 2 hours. If you want to use it better buy some 1.25" lowering springs.
Old 05-27-2011, 09:31 AM
UMI Performance's Avatar
The Sportlines and tunnel mounted torque arms are a mismatch of items that don't work well together. The Sportlines do not have good rates and they sit the car way too low to the ground. Combine this with a low hanging torque arm for a big exhaust and it won't be fun.
If you want to run a tunnel mounted torque arm for long tubes you need to run stock springs or a much less aggressive lowering spring.
If you decide you want the slammed look I recommend a full length torque arm like this- www.umiperformance.com/2205
I hope that helps,
Ryan
Old 05-27-2011, 11:04 AM
LSxWS.6's Avatar
im just guna deal with it and make it work, may suck but so do these cars to mod lol the car has good power so i want to keep the spohn tq arm, thanks for your help ill just have to deal or have some1 fab me up a custom dsl loop crossmember since ij hsave to get a true dual made for the car as it is
Quick Reply: Help! Anyone running a Spohn DSL Crossmember (part#405) with Eibach Sportline Springs
