Old 04-25-2016, 05:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
what is the best transmission cooler to buy?
Old 05-26-2011, 12:47 AM
WhiteGXP313's Avatar
Default what is the best transmission cooler to buy?
The link in the sticky for the trans cooler right up is bad.
I just ordered a shift kit and since ill be doing that i mind as well get a cooler so my question is which is the biggest and best one i can buy?
Old 05-26-2011, 05:37 AM
94ss06gxp's Avatar
IIRC i believe there are a few members here running an Imperial kit from advance auto. its like $50
Old 05-26-2011, 07:28 AM
JessmoMonteSS's Avatar
Weird, the link worked for me 2 weeks ago. It's a Hayden OC-1404. Found it on Ebay for $50 shipped.
Old 05-26-2011, 08:02 AM
Jeremy@RPMTransmissions's Avatar
The best cooler we have found is the B&M 70297. It is pricey but it WORKS!
Old 05-26-2011, 08:29 AM
Randal McSandal's Avatar
I run the B&M 24k. I know a lot of others on here do as well.
Edit: Just realized I'm in the LS4 section. Oops!
Old 05-26-2011, 08:38 AM
rvd9431's Avatar
I bought the flex-a-lite 18K GVW cooler from jegs, hottest my trans has gotten was 186 and that was after driving for 30 mins then sitting in dead stop traffic for 20 mins in 94 degree heat
pretty cheap too, under $50 with shipping
http://www.jegs.com/i/Flex-a-lite/40...oductId=756324
mounted it on the radiator support all the way on the bottom right where air flows through the bottom of the bumper
Old 05-26-2011, 09:58 AM
thanks, i think im going to order it
Edit: whats GVW?
Edit Edit: Nvm i googled it loll
Old 05-26-2011, 02:41 PM
LS1 Racing's Avatar
That's what I'm running. 30,000 lb GVWR, IIRC.
Old 05-26-2011, 07:47 PM
06silverss's Avatar
I am also thinking of adding a tranny cooler since i will be doing a shift kit and fluid change soon.
Old 05-26-2011, 07:53 PM
vroom_vroom's Avatar
i have always run a b&m cooler i put a derale on the gxp and im quite happy with it,
there are some horror story's running around here about an lines leaking on the trans coolers with the gxp, my trans doesn't need any xtra help tearing it self apart so i go with what has worked in the past trans line and double clamps
Old 05-26-2011, 08:02 PM
rvd9431's Avatar
i didnt double clamp the splice lines but i did double clamp where the trans line goes on the cooler, 2K miles so far 0 leaks, I check it once a week or so, I used 3/8" air hose brass splicers to join the lines, works great
Quick Reply: what is the best transmission cooler to buy?
