Diff swap--- 95 into 02 ?
Old 05-27-2011, 10:21 PM
Darth's Avatar
Default Diff swap--- 95 into 02 ?
I'm relatively new here and also to F bodies, so please be gentle!
I've done a lot of reading but can't seem to find a solid answer to my question. Can a 95 Z28 diff be swapped into an 01 WS6? The 01 has traction control.
From what I can find, there could be an ABS issue. Also, when I look up various parts (housing, axles etc) I can't seem to find much interchangeability and yet I find it hard to imagine that GM made two completely unique diffs for these cars.
Thanks in advance.
Carl
Old 05-27-2011, 11:15 PM
01ssreda4's Avatar
We need more specifics. Whats the drivetrains in each car? V8/V6/M6/A4???
Will it physically fit? Absolutely. Will the e-brake, abs, trac, speedo work? Depends. Whats wrong with the 01's rear? You can just pull the guts out of the 95 rear and swap them in the 01.
Old 05-27-2011, 11:18 PM
Darth's Avatar
Thanks for replying.
The 95 diff is from a T56 car.
The 01 that needs a diff is a WS6 A4 car. The guts in it are pretty much shredded.
From what I can figure, the 95 diff will be a 3.42 and the 01 will be 3.23. The gear change is fine, actually desirable.
Old 05-28-2011, 12:09 AM
01ssreda4's Avatar
Pull the posi and gears out of the 95 and put them in the 01 housing. 01 have TCS?
Old 05-29-2011, 10:13 AM
philsblwnz28's Avatar
I just put a 95 Z28 rear w/ 3.73 gears into my 98 Z28 lastnight. All I did was swap the backing plates, axles, new bearings and seals. It was easy as that. Something I dont have is TC, ABS, E-Brake, I cant help you there. I went from 3.23 to 3.73 and a POSI instead LSD. I love it so far. Big Diff in getting out of the holio
