front shock install questions
hey guys,
I'm in the middle of installing my front shocks/springs... question is, how far down do I need to tighten the shock nut? I've found nothing about where the shock nut should sit or anything... can anyone tell me, definitively? Or does not really matter because the weight of the car will determine how/where the spring will sit anyway? I've not really done this before so pointers would be helpful!
I haven't done my install yet, but have heard if it's not tight enough you will get some popping. I know that doesn't answer your question, but I've heard you won't know until it's back together. So, don't think: Oh, it will be tight enough. I try to read most of the install threads to keep from getting stuck. That's one of the questions I have for Sam when I call.
You tighten down the shock nut until it completely bottoms out. The only purpose of the nut is to hold it all together, it isn't to determine how the spring sits at all. I forget the actual torque spec, but when I had done mine I used the german torque spec gootentite - say it out loud
