UMI TQ and Moser 9"
UMI TQ and Moser 9"
i just put a moser 9" in the car and im having issues with my UMI tunnel mount TQ, ive finally got it on the the rear using the other holes in the bracket, but it hits the tunnel when the suspension is loaded
any insight welcome thanks chris m.
Hello,
Like mentioned this is common with all aftermarket torque arms. You have to remember the 9" rear end is much larger than the factory rear end, the larger the housing gets the closer the torque arm will get to the tunnel area. The aftermarket torque arms like ours aren't small either so you have a big torque arm and a big rear end.
Clearancing the tunnel area is going to be a must no matter what. Also check the make sure the the rear end is centered under the car. If not using a panhard bar you can center the rear end in some cases and gain some clearance.
I hope that helps,
Ryan
I hope that helps,
Ryan
Which set of holes on the rear bracket? I'm trying to use the outside and I'm having a major issue getting the holes to line up. It's right against the driveshaft(using a 3.5 inch drive shaft now with the 9inch).
I have the relocation kit off the trans too, which holes on that should I use?
