a.c question
Old 05-28-2011, 09:13 PM
subbie racer's Avatar
Default a.c question
my a.c is now stuck on the heat vent, and florida is already up to 99 degrees, any idea of what part im looking for? i plan on going to LKQ junkyard next week for this part, ABS and a steering wheel
thanks.
Old 05-29-2011, 12:24 AM
samson_420's Avatar
Most likely there is a break in the vacuum line that controls the blend door diaphragm.
Old 05-29-2011, 12:46 AM
thanks, i found something online about it, couldnt find it at first, gave up and ended up posting on here then found it
Old 06-01-2011, 09:08 PM
so i followed the vacuum lines they are all good, but i have a question, the vacuum line to the intake, does it go under the intake or into the back
Old 06-04-2011, 12:06 PM
samson_420's Avatar
Back somewhere I believe. I'm not by my car to check.
Old 06-04-2011, 01:12 PM
alright thanks, later on today im going to the car show and meet up with someone that has an 01 trans am im just gonna follow the lines and see for myself
Old 06-04-2011, 07:15 PM
2001NBMZ28's Avatar
No vacuum lines under the intake - be sure to look at the check valve near the PCM and the line to the vacuum storage tank under the passenger side front frame rail.
Old 06-05-2011, 11:43 AM
kevindglenn's Avatar
I'm obviously a little late in responding...so I'm glad you seem to have it figured out.
Old 06-11-2011, 09:58 PM
well it turns out the vacuum line behind the intake came undone and slipped under the intake all fixed and finally enjoyin my a.c since Florida right now is just crazy with the heat
