oil leak
oil leak
I have a 96 Formula leaking from the front main seal and at place on both sides that the oil pan, block and timing cover meet. Everytime I turn on the car it won't leak and then all of a sudden it will build up pressure or something and will leak like crazy. Is this normal? I have replaced the front main seal and it did not stop the leak.
Village Troll
It reads like your front seal is worn and very possible your oil pan gasket is too. At least check to see if the bolts on the oil pan are tight. A front oil seal is not a hard install. It just involves pulling the crank pulley. Shoebox has a page on how to remove it. www.shbox.com
Has the timing cover ever been removed?
Not true. There should be absolutely no positive pressure in the crank case. That's what the PCV system is for. If there is enough pressure "built up" in the crank case to force oil past gaskets and seals there are other problems to worry about.
Well I changed out the pcv valve out and o habe changed the front seal already with a felpro one but no luck. I'm guessing that replacing everything will be worth a try to get this leak controlled
Village Troll
Did you clean the hub of all rust/corrosion before putting the new seal on? Reason I ask is the seal may ride differently being new and could come into contact with the rust/corrosion on the crank snout which would act like sandpaper and wear the seal out quickly.
As far as the oil pressure is concerned that could be a huge problem or could just be the sender. You can connect an mechanical gauge up to the port just above the oil filter to verify. Does the pressure fluctuate at all while the engine is running or does it stay fixed on 80psi?
The pressure stays there the whole time. I did not clean the hub completely so that might be an issue. But I have bigger issues now since my trans decided to start.shifting out of 1st at 5000+ rpms while cruising now and feels like its giving out on me horribly!
