Starter access with Long tubes. Ebay and Pacesetter
Old 05-31-2011, 04:27 PM
fastcars95's Avatar
Default Starter access with Long tubes. Ebay and Pacesetter
Can anyone access there starter with longtubes. I have pacesetter L/Ts and a set of Speed Daddys Kooks headers. I'm in the middle of installing the ebay headers and there is no starter access. I cant even see the one inside starter bolt.
If I need to remove the starter I have to pull the passenger side header.
Are the Pacesetter long tubes going to give more access. They look alot longer then the ebay headers so I was thinking they might merge past the starter ?
What headers would you run if you had both to choose from.
Old 05-31-2011, 05:12 PM
jkicak's Avatar
i just installed pacesetters on my car and they are not even close to the starter.
Old 05-31-2011, 05:16 PM
fastcars95's Avatar
Could you remove your starter without the header getting in the way
Old 05-31-2011, 05:21 PM
jkicak's Avatar
yeah, since i had the starter out when i put the header in. like i said there is plenty of room
Old 05-31-2011, 06:08 PM
SoxXpupPeT's Avatar
IDK about the speed daddy headers. But my headers from ap1ap2 clear very well.
Old 05-31-2011, 06:25 PM
badass383formula96's Avatar
ive had 3 sets of pacesetters, never had a clearance problem with anything at all. i dont even have to lift the motor to install the last set i put on. On a side note ive installed 2 sets of ebay headers both were close to the starter and oil filter making them a lil harder to remove.
Old 05-31-2011, 07:05 PM
fastcars95's Avatar
[QUOTE=badass383formula96;14983049]ive had 3 sets of pacesetters, never had a clearance problem with anything at all. i dont even have to lift the motor to install the last set i put on. On a side note ive installed 2 sets of ebay headers both were close to the starter and oil filter making them a lil harder to remove.[/QUOTE
Have you ever had a starter go bad because the header sits so close.
I dont think its that big of a deal that I don't have easy access to the starter as long as its not going to kill it. I have had no reason to remove my starter in the past.
Old 06-01-2011, 01:40 AM
FormulaJoe's Avatar
I also have ap1ap2 headers and I can get the starter in and out with them in, it's not too tight of a fit.
Old 06-01-2011, 04:18 AM
fastcars95's Avatar
Maybe its my aftermarket starter. I'll try a stock one to see if I get more clearance.
Quick Reply: Starter access with Long tubes. Ebay and Pacesetter
