Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
About to pull the trigger on a cam. insight?
Old 06-01-2011, 03:57 PM
eggsnmilkctsv's Avatar
Default About to pull the trigger on a cam. insight?
I have been wanting to install a cam for some time now, i love the sound of a "BIG" cam and when i say big i mean really big almost to the point where it is not wanting to idle. As bad as this sounds im not worried about alot of power gain i am more focused on achieving this specific sound. This is going to be a cam only car. Any help on finding what cam could achieve this would help me out.
mods on the car include kooks headers, B&B exhaust no cats, X-Pipe, K&N intake and a tune.
Thanks
Tim-
Old 06-01-2011, 05:33 PM
ZGLASS's Avatar
search trex cam.
http://www.youtube.com/watch?v=YMXxCWxAKF8
Old 06-01-2011, 06:04 PM
STAGEUP's Avatar
I recommend the tick performance polluter cam. My buddy has it, and man o man does it thump!
Old 06-01-2011, 06:30 PM
itsslow98's Avatar
Any of the above will do what you want and make great top end power. MS3 sounds pretty good as well.
Old 06-01-2011, 07:13 PM
EasyZ06's Avatar
I heard the texas speed magic stick 4 recently and it sounds very nice too. Should be able to find a bunch of youtube videos of these. They make some good power too.
Old 06-01-2011, 07:38 PM
whisler151's Avatar
What are your goals for the cam?
I have the SNL v.2. Its a decent size cam that was designed around a 4000lb car, so the power is where you need is. www.snlperformance.com/home.html
http://www.youtube.com/watch?v=5LyHF-gOiM0
If I were to do any other cam I would call the guys at Texas Speed.
http://www.texas-speed.com/shop/cate...MID=4&catid=44
Old 06-01-2011, 08:35 PM
ZGLASS's Avatar
I think for a caddy something in the 228-232 .612/.612 111+2 would be better for a heavier car like the caddy. It will still be pretty damn choppy and make way better power under the curve. I have basically the same cam in my c5z06 mines on a 113lsa tough not quite as choppy.
http://www.youtube.com/watch?v=aH9480P7n0A
http://www.youtube.com/watch?v=qhpL2...eature=related
Old 06-01-2011, 10:18 PM
SilveradoSS500's Avatar
BINGO, make sure you keep this in mind. It's not like you have a light weight C5 Z06, which most of the "off the shelf" cams were spec'd for.
You need something with TQ in mind, I had a baby 219/225/561 114LSA, sounded nasty, rev'd fast and I could take the big cam'd V's and maggies V's.
-Adam
Old 06-01-2011, 10:25 PM
STAGEUP's Avatar
Just go with a huge cam. My cam was designed for a 3300 lb car, and it makes my 4000 lb v run some serious times. U go with anything less than an MS3, you're going to regret it.
Old 06-02-2011, 04:44 AM
GhettoTy's Avatar
Rule of thumb for a cam is after you pick one out, go one step bigger.
Old 06-02-2011, 06:40 AM
whisler151's Avatar
I agree.
Old 06-02-2011, 09:14 AM
big reg's Avatar
Whisler, do you have any problems with your cam and the lightweight flywheel? I have a 16.5lb flywheel going in and my cam is a little bigger but on a 113 lsa so the overlap is almost identical.
Old 06-02-2011, 09:52 AM
whisler151's Avatar
In stop and go traffic it can get annoying, but I think that is the same with any manual car. I had the 18lb flywheel for about a year before I did the cam so there wasnt any real change. If you did both at the same time I would expect you to have problems. But as long as you are used to the way the car drives with the flywheel you will be fine.
Old 06-02-2011, 12:02 PM
hnic91's Avatar
I think I'm about to go with the Livernois Stage 2R cam, what do you guys think about that cam?
236/236 lift: .602/.602 lSA: 113
Old 06-02-2011, 08:44 PM
JJSimon904's Avatar
I love mine. It is the Thunder Racing RapTR cam. 236/242 .615/.615 111. All cams this big will take a bit of time logging and tuning to get it as drivable as stock. Mine pulls w/o bucking from 1000rpms on up and the power really kicks in over 3k. It is a lot of fun.
http://www.youtube.com/watch?v=eQsRzWzx64A
http://www.youtube.com/watch?v=Qs2nL_UGLxU
Old 06-02-2011, 10:25 PM
98cobra's Avatar
What are those serious times you are running?
Old 06-02-2011, 11:17 PM
itsslow98's Avatar
very low 12s at 117 on motor cam only. pretty damn good for these cars.
Old 06-02-2011, 11:18 PM
STAGEUP's Avatar
12.1 missing 4th gear trapping 116-117 mph. n/a. Cam only.
12.2 on nitrous trapping 124-125 mph. On a 100 shot, spinning all through 1st and 2nd.
With the baby seat in the car, and the stroller in the trunk.
Old 06-02-2011, 11:25 PM
Now this is what im looking for, this sounds really good. How difficult was it to get the tune right?
Old 06-04-2011, 12:29 PM
JJSimon904's Avatar
Nice times! All my track times include the baby seat mod as well.
It just takes some patience and some know-how. If you haven't done any tuning before, you might get someone who knows how to help you with it.
I'm a bit down on power (only dyno'd 392) but I think I have other issues going on on top of needing more intake and bigger injectors. Others with this cam are making a lot more power on the dyno with similar setups. If you go with this cam, a FAST intake will help out a lot.
Quick Reply: About to pull the trigger on a cam. insight?
