About to pull the trigger on a cam. insight?
I have been wanting to install a cam for some time now, i love the sound of a "BIG" cam and when i say big i mean really big almost to the point where it is not wanting to idle. As bad as this sounds im not worried about alot of power gain i am more focused on achieving this specific sound. This is going to be a cam only car. Any help on finding what cam could achieve this would help me out.
mods on the car include kooks headers, B&B exhaust no cats, X-Pipe, K&N intake and a tune.
Thanks
Tim-
Thanks
Tim-
What are your goals for the cam?
I have the SNL v.2. Its a decent size cam that was designed around a 4000lb car, so the power is where you need is. www.snlperformance.com/home.html
http://www.youtube.com/watch?v=5LyHF-gOiM0
If I were to do any other cam I would call the guys at Texas Speed.
http://www.texas-speed.com/shop/cate...MID=4&catid=44
I think for a caddy something in the 228-232 .612/.612 111+2 would be better for a heavier car like the caddy. It will still be pretty damn choppy and make way better power under the curve. I have basically the same cam in my c5z06 mines on a 113lsa tough not quite as choppy.
http://www.youtube.com/watch?v=aH9480P7n0A
http://www.youtube.com/watch?v=qhpL2...eature=related
You need something with TQ in mind, I had a baby 219/225/561 114LSA, sounded nasty, rev'd fast and I could take the big cam'd V's and maggies V's.
-Adam
Just go with a huge cam. My cam was designed for a 3300 lb car, and it makes my 4000 lb v run some serious times. U go with anything less than an MS3, you're going to regret it.
Whisler, do you have any problems with your cam and the lightweight flywheel? I have a 16.5lb flywheel going in and my cam is a little bigger but on a 113 lsa so the overlap is almost identical.
In stop and go traffic it can get annoying, but I think that is the same with any manual car. I had the 18lb flywheel for about a year before I did the cam so there wasnt any real change. If you did both at the same time I would expect you to have problems. But as long as you are used to the way the car drives with the flywheel you will be fine.
I love mine. It is the Thunder Racing RapTR cam. 236/242 .615/.615 111. All cams this big will take a bit of time logging and tuning to get it as drivable as stock. Mine pulls w/o bucking from 1000rpms on up and the power really kicks in over 3k. It is a lot of fun.
http://www.youtube.com/watch?v=eQsRzWzx64A
http://www.youtube.com/watch?v=Qs2nL_UGLxU
Now this is what im looking for, this sounds really good. How difficult was it to get the tune right?
I'm a bit down on power (only dyno'd 392) but I think I have other issues going on on top of needing more intake and bigger injectors. Others with this cam are making a lot more power on the dyno with similar setups. If you go with this cam, a FAST intake will help out a lot.
