TCM/IPC fuse blowing after Whipple install
Sounds like a short in the wiring to me, I think I have a wiring problem to my purge solenoid from my install. I only moved my purge soliniod just over an inch away from it original location and now I throw a code for it.
Hopefully you can back track wires you moved. When you lowered the rad did you make sure the wires to the EBCM were out of the way?
TCM could even be a speed sensor wire if you removed your wheels for the install.
Also take a close look to make sure all your grounds are solid. I know they have a bad habit of tripping fuses. Good luck and keep us posed, I know your probably going crazy to have that beast running!
Thanks, that's good info. Anybody have a diagram?
Does it happen when you turn the key to 'on' position or when the car is turning over? I have never done a hot wire fuel pump, butI know it takes some re-wiring. It could be when the fuel pump is priming, if it occurs right away. If so I would start there and check all connections.
haha yeah, I was just trying to think of something you may have changed with the new set up! I dont have a wiring diagram, and not sure what the hot wire kit ties into to get more power, just thought I would throw it out there!
Finally found it last night. The Throttle body wire was rubbing on the idler bracket we had to add for the new SC. One of the wires had been pinched a little and was grounding out.
Whew! I'm glad that's over. I found it by disconnecting EVERYTHING... intercooler pump, TB, MAF, temp sensor, transmission connectors, coil packs... everything. After I verified the fuse did not blow with everything dissconnected, it was just a process of connecting things one by one and waiting for the fuse to blow.
GOOD LORD is this blower loud!!
